belliemom
#1 Posted : 11 years ago
belliemom
Could you give me any helpful hints on installing a new ignitor for my oven. AKA what and how to do it myself in laymans terms... Thanks
festeraddams
#2 Posted : 11 years ago
festeraddams
Pull the panel off (assuming bake) the bottom, detach the flame spreadder, take the couple screws holding the burner in out. Put a drop of oil on the threads on the back of the flange on the burner for the ignitor, unscrew ignitor, (if you got one with a plug unplug the old one, plug the new on in, if you have the CERAMIC wire nuts, cut the wires, strip and use the wirenuts) - all of this of course with the unit unplugged..... reverse process.....
Kitchenaid Gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Travelguy 11 years ago
Oven wont heat up (Oven Repair (including Ranges and Cooktops))
by shellyrodriguez 11 years ago
Frigidaire Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by GHog 12 years ago
ge wall oven wont heat up (Oven Repair (including Ranges and Cooktops))
by henson1166 12 years ago
lights come on oven wont heat up (Oven Repair (including Ranges and Cooktops))
by fxe81hd 13 years ago
by CLL 13 years ago
whirlpool oven wont heat up (Oven Repair (including Ranges and Cooktops))
by tim hinson 14 years ago
Thermador Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by DonD 14 years ago
magic chef wall oven wont heat up.it ignites (Oven Repair (including Ranges and Cooktops))
by barbara1 14 years ago
Oven wont heat up after locking the door (Oven Repair (including Ranges and Cooktops))
by kescrig 15 years ago
by bigdaddy5 15 years ago
maytag oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Dan-o 15 years ago
by mamoody 16 years ago
oven wont heat up by itself (Oven Repair (including Ranges and Cooktops))
by garhd 17 years ago
Kenmore gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by searvle 17 years ago
