CHERIE KING
#1 Posted : Thursday, February 27, 2014 8:16:38 AM(UTC)
CHERIE KING
The washer will not agitate or spin. It will drain the lid switch I think is good and the coupler is good. I think the clutch or transmission has a problem. I have taken them off nothing look broken. What else could be wrong?
sidfink43
#2 Posted : Friday, February 28, 2014 5:23:17 PM(UTC)
sidfink43
Since it will drain this means the motor is working and the lid switch is ok.
This really sounds like a coupling problem. I would change it out. Sometimes a problem is not visible unless you take it apart.
CHERIE KING
#3 Posted : Friday, February 28, 2014 6:38:46 PM(UTC)
CHERIE KING
The coupler is not broke I have taken it apart and looked at it I have also t as Ken the transmission apart and do not see anything broken but the gear on the shift did not want to move freely it was very stiff we freed it up it still does not work any suggestions.
sidfink43
#4 Posted : Saturday, March 1, 2014 4:09:43 AM(UTC)
sidfink43
If the outer case of the clutch is not turning when the machine is supposed to be agitating or spinning then that would suggest the transmission is the problem. If it were only the clutch it would agitate but not spin.
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
washer will not agitate or spin (Washer Repair)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
Estate Washer will not agitate or spin (Washer Repair)
by Greenday1827 7/19/2013 12:34:47 PM(UTC)
by mike145 6/25/2013 5:11:49 PM(UTC)
Kenmore washer will not agitate or spin (Washer Repair)
by dlacacres 5/8/2013 9:46:24 AM(UTC)
GE washer will not agitate or spin (Washer Repair)
by st smith 4/1/2013 7:11:12 AM(UTC)
Newer GE Washer will not agitate or spin (Washer Repair)
by dwolfe 9/11/2012 8:34:44 AM(UTC)
my washer will not agitate or spin (Washer Repair)
by angelsthree 5/3/2012 5:49:18 AM(UTC)
Maytag washer will not agitate or spin (Washer Repair)
by roscoepcoltrain 4/19/2012 4:55:32 AM(UTC)
Maytag Washer will not agitate or spin (Washer Repair)
by Mbat4 2/13/2012 3:12:24 PM(UTC)
Belarus wpatetec 12/19/2011 4:45:27 PM(UTC)
Motor Hums But Washer Will Not Agitate Or Spin (Washer Repair)
by john@ljolson.com 10/22/2011 12:14:27 PM(UTC)
Crosley washer will not agitate or spin. (Washer Repair)
by Jinxd66 4/14/2011 4:54:38 AM(UTC)
