rtd2
#1 Posted : Friday, February 7, 2014 10:37:38 PM(UTC)
rtd2
6 yr old washer with no prior issues except for I replaced the drain pump 2 years ago. A few days ago shortly after starting a load to wash the machine indicated code NF (No Fill) . I've checked the obvious things listed on Samsung trouble shooting site such as making sure water inlet screens are clean, using traditional steel braided hoses (No flood safe hoses ). I Have plenty of water pressure entering the washer tub but I notice as soon as I power the washer on the drain pump is running continuously and if you start a wash cycle the pump is pumping the water out thus causing the NF code!.Any thoughts?
model is wf206bnw/xaa
rtd2
#2 Posted : Monday, February 10, 2014 8:28:29 AM(UTC)
rtd2
Over 140 views and no one has any ideas? Relay? Main board?
roger sloan
#3 Posted : Monday, March 24, 2014 5:18:13 AM(UTC)
roger sloan
I Have Same Problem ,did You Find A Fix For It?
rtd2
#4 Posted : Tuesday, March 25, 2014 6:58:11 AM(UTC)
rtd2
Thankfully I ran across a new washer and dryer set for,a great deal. (got away from front load) That said the fix for my problem was replacing the main board. Cost about 160.00 depending on vendor. The part #is located on a label on the board itself. It's a simple repair, connections just unplug, plug in new board
