waveraider
#1 Posted : Thursday, January 30, 2014 9:00:51 PM(UTC)
waveraider
All lights light up accept start. Nothing happens when start is pushed. Any help is appreciated.
#2 Posted : Saturday, February 1, 2014 1:59:39 AM(UTC)
Parts for Whirlpool KUDP01ILWH5 Dishwasher - AppliancePartsPros.com
Remove power from the unit.
Disconnect the control panel from the control board.
Check the start button output with a meter. See the tech sheet.
Sometimes it is just a dirty connection.
But as you can see the keys share circuit tracks (wires) so other keys woul also not work terefor I do not think this is yur problem.
If the start ket checks out OK then odds are that the control board is bad.
File Attachment(s):
KUDP01.pdf (1,009kb) downloaded 18 time(s).
waveraider
#3 Posted : Saturday, February 1, 2014 8:25:08 AM(UTC)
waveraider
Yes I Just Had To Unhook The Ribbon Connector Then Plug It Back In
waveraider
#4 Posted : Tuesday, February 4, 2014 6:46:10 PM(UTC)
waveraider
I've opened up the control pannel and unhooked the board. That has worked twice now but only for one wash each time I unhooked it. Then I get no lights at the start button again. Does this sound like control board or touch pannel should be replaced?
#5 Posted : Tuesday, February 4, 2014 11:31:23 PM(UTC)
Sounds more like a control board problem.
It is best to check the start key with a meter.
If it checks out OK then the odds are higher that it is the control board.
Kitchen Aid Dishwasher won't start - has power (Dishwasher Repair)
by kizzy 3/2/2010 3:20:55 PM(UTC)
Kitchen Aid Dishwasher Won't start (Dishwasher Repair)
by Moses 6/4/2009 5:11:02 AM(UTC)
