DDEBRUS
#1 Posted : Sunday, January 19, 2014 11:20:20 AM(UTC)
DDEBRUS
i have replaced the cycling thermostats and continue to have issues with it taking too long to dry clothes. Would it help to replace the thermo fuse?
fairbank56
#2 Posted : Sunday, January 19, 2014 12:36:05 PM(UTC)
fairbank56
Double check the model number, doesn't come up. If dryer is heating, thermal fuse is ok.
Eric
#3 Posted : Monday, January 20, 2014 2:12:19 AM(UTC)
The most common cause of long dry times is a partially plugged vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
Guest (5)
GAS DRYER TAKES TOO LONG TO DRY, OE DOESN'T DRY AT ALL. (Dryer Repair)
by MAYTAG MANIA 7/20/2022 2:05:06 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Samsung takes too long to dry (Dryer Repair)
by Scottiedg 4/23/2017 3:59:22 PM(UTC)
dryer takes too long to dry (Dryer Repair)
by cdhenson68 1/1/2015 11:54:59 AM(UTC)
Takes too long to dry (Dryer Repair)
by myersv 4/1/2014 2:35:28 PM(UTC)
Maytag gas dryer LSG7904AAE takes too long to dry (Dryer Repair)
by mr1022 1/2/2012 11:27:21 AM(UTC)
whirlpool leb6400lw0 Takes too long to dry (Dryer Repair)
by itsmatt 6/12/2011 11:26:33 AM(UTC)
by mark stevenson 5/3/2011 8:38:32 PM(UTC)
Whirlpool Dryer (gas) takes too long to dry on Energy Efficient mode (Dryer Repair)
by Ranae 12/12/2009 8:16:06 AM(UTC)
Roper dryer takes too long to dry (Dryer Repair)
by bluefitness 8/15/2009 6:16:45 PM(UTC)
by Sean O 3/3/2008 6:33:49 AM(UTC)
Takes too long to dry:Duet (Dryer Repair)
by Scottpiggs 8/8/2007 2:37:09 PM(UTC)
