kenmore oven model# 79096112401 will not heat up everything else works is it the clock control panel
Yes it is probably the clock/control board but I would check thet the wires to the control board and the elements are OK. Also I am assuming that the oven stays in preheat and never comes ready. If it does show that it is ready then it could be the oven sensor. Part number: AP4587739
THIS FORUM IS DEAD!!!!!!! |
