Microwave will not heat. Everything else works correctly, when you put something in and start it, nothing appears different with the exception that whatever temperature the item went in, it comes out unchanged.
Originally Posted by: David Lindsay ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Microwave will not heat. Everything else works correctly, when you put something in and start it, nothing appears different with the exception that whatever temperature the item went in, it comes out unchanged. I have the exact same problem with mine and its not even a year old.
