kthygesen
#1 Posted : Monday, December 16, 2013 6:45:37 PM(UTC)
kthygesen
New to forum. Sorry if I am posting issue that is already posted. I read thru most and searched, but none where like my issue.
My upper oven did not heat over 200 degrees no matter the setting when I first bought my house. It would take over 45 min just to get to preheat to 200 degrees. I had a tech come out and tell me it was the control board. I replaced the control board myself via APP site and tried the oven again. although, it now heats up to desired temp setting, Oven still takes 30+ minutes to heat. It will not maintain temperature once you place a meal in it. I have a thermometer in oven and temp drops 50 -75 degrees. Bottom oven works fine, so I swapped temp probes. Same issue. Bottom oven works, top has same symptoms.
Is it other small board that I have not replaced yet?
Thx,
Kevin
#2 Posted : Tuesday, December 17, 2013 12:53:41 AM(UTC)
Are you sure that the model number has a 0 at the end as I cannot find any info on this unit.
The below info is for a KEBV208MMT02.
Here are the parts
Parts for Whirlpool KEBV208MMT02 Wall Oven - AppliancePartsPros.com
Do both the broil and bake elements work?
The unit switches back and forth between the two elements in pre-heat and bake modes.
Could be one of them is burned out.
Looks like the other small board is for the door lock so should not cause your problem.
File Attachment(s):
KEBV208.pdf (351kb) downloaded 6 time(s).
Kitchenaid Double Oven Upper Oven very long Preheat (Oven Repair (including Ranges and Cooktops))
by kthygesen 12/16/2013 6:42:57 PM(UTC)
