fixitboy
#1 Posted : Tuesday, November 26, 2013 12:22:35 PM(UTC)
fixitboy
Our Thermador oven door no longer closes tightly. There is nothing visibly obstructing nor does anything visibly appear bent.
Google search seems to suggest replacing the hinges (#00487238).
Does one also typically need to replace the hinge support (#00415049) or does that have nothing to do with keeping the door closed?
Is there any way to fix/strengthen the hinge short of replacing the hinges?
#2 Posted : Wednesday, November 27, 2013 5:37:52 AM(UTC)
Sometimes just removing the door and re-installing it will fix this problem.
If the above does not work then I would replace the hinges.
Could be that part of it may be damaged or the springs have lost some tension.
See the below so yo have something as a reference.
Part number: AP2836969
Below is the hinge support also so you have a reference. Clicking on the picture will give you more views of it. These are usually OK unless you can see a problem with it.
Part number: AP2832441
Guest
#3 Posted : Wednesday, March 31, 2021 6:11:15 PM(UTC)
Guest
Can you fix the door of thermodore stove in Vancouver are and how much do you charge for that
Thank you
Guest (5)
