2 Pages<12
#11 Posted : 11 years ago
Well I am stumped.
I cannot think of anything that would cause the defrost relay to stutter.
Try forcing a defrost cycle to see if it will actually do a defrost.
Check the defrost thermostat. If it is deformed/bulged replace it.
Check across the control thermostat.
You should have 0 volts across it when the unit is on.
mansoura
#12 Posted : 11 years ago
mansoura
How exactly would I do this? Noob question, I'm sure.
mansoura
#13 Posted : 11 years ago
mansoura
Just to be sure, the control thermostat and defrost thermostat are the same thing correct? The voltage across what I know to be the defrost thermostat is indeed 0 V when the unit is on.
mansoura
#14 Posted : 11 years ago
mansoura
Ok I figured out what the control thermostat was. I tried to test the voltage across the two terminals and the whole thing went up in sparks! Needless to say the relay is fried. I have no idea why this happened. Could this be the reason it is messed up? It's obviously messed up now. Here's a pic:
mansoura attached the following image(s):
#15 Posted : 11 years ago
Yes it could be the cause of your problems.
Whirlpool Refrigerator not cold enough (Refrigerator & Freezer Repair)
by bsmcc 9 years ago
Frigidaire Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by wing471 9 years ago
Freezer cold but not freezing, refrigerator not cold enough (Refrigerator & Freezer Repair)
by tyltea1st@charter.net 11 years ago
Freezer & Refrigerator not cold enough (Refrigerator & Freezer Repair)
by HFrank 12 years ago
Freezer and Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by mahplane 13 years ago
by tonlam 13 years ago
Magic Chef Refrigerator Freezer work Refrigerator not cold enough (Refrigerator & Freezer Repair)
by tg06222 14 years ago
GE Profile Arctica Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by Snap50 14 years ago
Kenmore refrigerator not cold enough (Refrigerator & Freezer Repair)
by Malinda 14 years ago
by teresa in mo 14 years ago
by davidwaynesmith 14 years ago
Freezer and Refrigerator not cold enough (Refrigerator & Freezer Repair)
by fionmay 14 years ago
Side by side refrigerator not cold enough (Refrigerator & Freezer Repair)
by Bhedman 14 years ago
Frigidaire side by side refrigerator freezer working refrigerator not cold enough (Refrigerator & Freezer Repair)
by SSOWDERS 15 years ago
by mfd 17 years ago
2 Pages<12
