hurler72
#1 Posted : Monday, November 25, 2013 10:59:35 AM(UTC)
hurler72
I need HELP PLEASE...The washer, Ultimate Care II, will do all functions but will not drain. I have bailed the drum out but now what? does not appear anything is stuck under the agitator. Any ideas anyone?
Thank you!
fairbank56
#2 Posted : Monday, November 25, 2013 1:41:15 PM(UTC)
fairbank56
Is there any noise from drive motor when it should be draining? Does it spin? What is model number of the washer?
Eric
hurler72
#3 Posted : Monday, November 25, 2013 4:25:49 PM(UTC)
hurler72
Thank you Eric. I looked all over the washer and could not find a model No. Only this:
Whirlpool
Commercial Quality
Super Capacity Plus
10 cycle
3 speed motor
6 speed combination
If this helps at all.
Makes a slight hum from the drive motor and does not spin
Thank you
fairbank56
#4 Posted : Monday, November 25, 2013 6:37:34 PM(UTC)
fairbank56
So, washer fills and agitates but won't drain or spin? Remove washer cabinet and bypass the lid switch as per video's below. Release the two clips holding the drain pump to the motor. Pull pump from motor and move to the side (leave hoses connected). Place washer in spin mode. Will it spin without pump attached? If not, does motor shaft rotate? If not but motor is humming, rotate motor shaft clockwise as fast as you can. Does motor start? Model number is probably under lid. Should be 11 numbers (110.xxxxxxxx)
Cabinet removing Whirlpool direct drive washer - YouTube
Lid switch bypassing Whirlpool direct drive washer - YouTube
Eric
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
Maytag Washer Will Not Drain or Spin during White or Color Cycle (Washer Repair)
by ametz69 11/6/2012 5:52:41 PM(UTC)
