AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool LER7646EQO makes sound when turned on. Drum does not move
Here are your parts. Parts for Whirlpool LER7646EQ0 Dryer - AppliancePartsPros.comIf the sound is coming from where the motor is it could be a couple things. If it is a hum then perhaps just the belt has broken. If the sound is more like a buzz it could be motor problem. Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it. If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp. If nothing is jammed in there you will have to open it up and find the cause. If it rotates OK. This may take 2 people Open the door Manually hold the door switch closed Push the start button and manually rotate the drum in the correct direction. Watch your knuckles in case it starts up. If it does start up, odds are high that you need a new motor. Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit. |
THIS FORUM IS DEAD!!!!!!! |
Not quite sure how I overlooked that this was a dryer...but I missed the boat! Thank you for the correct information. :o
Dryer Repair
