SynchHD
#1 Posted : Saturday, November 9, 2013 1:23:11 PM(UTC)
SynchHD
The dryer stops when using the heat, and trips the fuse, so I have to reset the fuse in the fuse bow. This doesn't happen when using air dry (no heat). I was told that this is the thermostat, and it was easy to replace. Is this true? If so, it this the right replacement part?
#2 Posted : Sunday, November 10, 2013 4:43:30 AM(UTC)
Parts for Whirlpool YIED4400VQ1 Dryer - AppliancePartsPros.com
[COLOR="Blue"]I was told that this is the thermostat, and it was easy to replace. [/COLOR]
I doubt it is the thermostat. Even if the thermostat never opens the breaker should be able to provide enough power so that it does not trip.
I would check the heating element.
Unplug the unit and both wires at the heating element.
Measure the element, should be about 8 to 12 ohms.
Next measure from each element connector to the case/frame, both should be infinite ohms. If not the lement is grounded and need replacement.
There is also the possibility that the breaker has a problem and is tripping at too low of a current. To check this you would need a clamp on amp meter.
SynchHD
#3 Posted : Sunday, November 10, 2013 6:36:37 AM(UTC)
SynchHD
Is it still the heating element, even if the dryer works with heat for ~5 mins?
#4 Posted : Sunday, November 10, 2013 9:29:17 AM(UTC)
It can be but you have to check it.
There can be a number of causes, the heating element is just the one I think is the most likely.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
