compressor will not start, think it might be bad capacitor. how can I check to see if this is correct?
Looks like you gave a part number instead of a model number. Below is what comes up when I search the number. A model number may be more useful because what is required to help is the unit's wiring diagram Part number: AP4565263
You cannot do a definitive test of the capacitor unless you have a capacitor tester. They may check OK for not being open or a dead short with a multimeter but then will fail when the actual working voltage is applied to them. the usual routine is to check that the compressor is getting the correct voltage. Then check that the compressor windings measure OK and are not grounded. This also is not a definitive test as the compressor may have internal mechanical problems or winding to winding shorts. Check the compressor start device angain this can be an iffy test. If all else looks OK then try replacing the capacitor. |
THIS FORUM IS DEAD!!!!!!! |
You have been a member since:: 3/15/2018(UTC) Posts: 2
Summer will be going to scorching in India. Then the air conditioner can only offer the relief. To face the summer buy an Air Conditioner from the best electronics store in Amravati and get the bumper discount on the electronics appliances. Edited by user Monday, February 4, 2019 8:08:37 PM(UTC)
| Reason: Not specified
Originally Posted by: pizza compressor will not start, think it might be bad capacitor. how can I check to see if this is correct? Hi, everyone, I think if you know everything about it then it will easy for you to check it out. Otherwise, you should check it from the expert that has a brief knowledge of it. because there may a problem in other units as well.
Lg room air conditioner
(Heating, Ventilation, and Air Conditioning (HVAC))
by Guest
2/15/2022 11:49:19 PM(UTC)
Trouble with air conditioner..!!
by Henry_jew
6/21/2019 3:03:19 AM(UTC)
Samsung Air Conditioner Capacitor Replacement
(Refrigerator & Freezer Repair)
by kewarren6
3/8/2017 5:52:17 PM(UTC)
What size air conditioner should I install on my 3,000-square-foot house?
by kelvinsystem
12/20/2013 8:22:38 PM(UTC)
Model # WHIRLPOOL AIR CONDITIONER
by Manonbar
7/23/2013 12:19:57 PM(UTC)
GE air conditioner
by Eddie Brown
8/23/2012 2:28:43 PM(UTC)
Air Conditioner
by danconlan
7/23/2012 10:01:24 AM(UTC)
GE Air Conditioner
by 10690
6/15/2012 2:13:05 PM(UTC)
window air conditioner
by Ruth Ann Williams
5/22/2012 4:11:39 PM(UTC)
Frigidaire window Air conditioner fan bearing Noise
by Rory S Drake
3/23/2012 8:41:55 AM(UTC)
E1 Code On Air Conditioner
by seache
7/29/2011 10:54:17 AM(UTC)
air conditioner
by ajmn05
7/20/2011 3:02:25 AM(UTC)
central air conditioner doesnt blow cold air
by rgjessen
7/19/2011 9:01:57 AM(UTC)
frigidaire air conditioner
by jlmac27
6/17/2011 8:03:38 PM(UTC)
Air conditioner won't give cold air
by goelajay
6/8/2011 10:17:57 AM(UTC)
