I have a Kenmore compactor modle#665.13605790. It compacts part way then sounds like it is stripping gears. then I have to turn the start knob to return the ram. Can you tell me what might cause this problem? Thank you.
Originally Posted by: iapoppee I have a Kenmore compactor modle#665.13605790. It compacts part way then sounds like it is stripping gears. then I have to turn the start knob to return the ram. Can you tell me what might cause this problem? Thank you. There is a cycle switch on the left side of the control panel. In what position is it? Gene.
It is in the normal pack position.but I have tried both and it does the exact same thing.
Check this switch for continuity.
When the switch is in "solid pack" position, the "O" & "O-B" circuit should be closed and the "O" & "Y" should be open.
When the switch is in "normal" position, the "O" & "O-B" circuit should be open and the "O" & "Y" should be closed.
Replace the switch if the reading is different.
In order to provide the right part number for the switch I need the color of the control panel.
control panel is black in color
The part number for the cycle switch is AP3020726. Gene.
Thanks Gene Iwill get one and hopefuly that will fix my gear grinding compactor and make my wife a very happy camper.
Originally Posted by: Gene Well Gene,I replaced the switch and lubed eveything. The ram dosen't return and still sounds like stripped gears. What now
