jumpeeman
#1 Posted : Sunday, October 27, 2013 3:39:06 PM(UTC)
jumpeeman
I have a Dryer that says "Hotpoint" and also General Electric Co., Appliance Park, Louisville, KY and it started squeaking about a month or so ago. It's not constant. . .sometimes it's quiet and sometimes it squeaks quite loudly. It sounds like it's coming from the front ~ I think I replaced the rear bearing already ~ the door is off in the back and I can see and hear the rear bearing and it looks and sounds good. Otherwise the dryer works great. . .
Questions are:
1) What do I need to disassemble to get to the front workings of the drum/roller/bearing/slide/glide assembly?
2) Are there disassembly/assembly instructions somewhere for this dryer?
3) If the sound is coming from the front, what are the parts that I should order and replace?
Thanks so much for your help!
PS the serial number is ZL2 12595H and here's a picture of the model/serial number plate:
UserPostedImage
jumpeeman
#2 Posted : Saturday, November 2, 2013 6:37:03 AM(UTC)
jumpeeman
Anybody out there have any specific parts recommendations or nice hi-res parts diagram that can help me out? I'm being pretty specific on the type of noise, it's location and even the model and serial number. . .just want to know exactly what parts near the front of my particular dryer that have anything to do with the support and/or rotation of the drum could cause a squeaking sound when rotating.
Thanks in advance for your help with this squeaking issue!:(
