I had to replace the Door Lock Assembly, that was easy, but now when I start the washer it just keeps buzzing. It works fine, but keeps buzzing the whole time the washer is on.
I did not replace the striker, only the door lock assembly, do I need to replace the striker?
:confused:
I am having the same problem. did you find out what was causing this?
