my wash cycle will only work on the last wash minutes(6). it works fine on this number but none of the higher wash numbers will advance thru wash cycle
The motor is not working in high speed wash. Last 6 minutes of agitation is in low speed. Remove the cabinet and check the blue wire at the motor connector. Probably burned/broken/corroded. If this is the case, you would need to replace the wire terminal in the connector housing. If the connection is ok, the timer may be defective.
Eric
