just replaced both igniters in oven as the oven would not come on. oven works fine now but broiler igniter is on for 6-7 minutes before gas valve clicks open to allow gas delivery. gas pressure seems low. i see no difference between low or high broil flame. i need to blow at the broiler to get it to light. if i leave the door closed after turning on broiler it will not light until i open the oven door, then there is a significant whoosh as the gas blasts on with back flash out the top of the oven door.
