george28
#1 Posted : Monday, October 14, 2013 9:00:13 AM(UTC)
george28
Hi when i started the dryer it just hummed. I tried giving it a turn while pressing the start button and it started to work. Now it appears to be working fine. I'm afraid once a get a full load in the dryer it wont start again. What could this be. I checked the belts etc and it appears to be fine. Thx
#2 Posted : Thursday, October 17, 2013 1:01:29 AM(UTC)
Most likely the motor is on it's last legs.
Try turning the drum by hand in the correct direction. It should turn fairly easily.
If not you may have a drum mounting problem that is putting too much load on the motor,
Also if you get heat when the motor is not turning it could be a problem with the centrifugal switch on the motor. May be stuck in the activated position.
This could be just that it is dirty.
