Lizard1
#1 Posted : Monday, September 30, 2013 11:40:35 AM(UTC)
Lizard1
We have Maytag Neptune clothes Washer MAH8700AWW. The washer works when you select Cold Water or Hot Water; however, when you select one of the automatic temperature settings listed in Red (Warm/Cold; Hot/Cold, etc.) the water continues to fill, even when powered off. Your customer service said to replace the Sensor Pressure Assembly, which we just did, but this did not fix the problem. Can you please tell me what we need to do? :confused:
HumboldtRepairMan
#2 Posted : Monday, September 30, 2013 5:18:07 PM(UTC)
HumboldtRepairMan
As you said the water keeps coming in even when the unit is turned off if that's the case you need to replace #15 & #19 on this list the water inlet valves..........The water pressure switch or sensor only works during the unit while it's on controlling the water level while in use. But since your problem is also when it's shut off the valves are your problem.
02-Control Panel, Dispenser parts for Maytag MAH8700AWW - AppliancePartsPros.com
