2 Pages12>
wolf234
#1 Posted : Monday, September 23, 2013 11:08:26 AM(UTC)
wolf234
The washer on wash cycle will not agitate but will spin out clothes when this happened smoke starting coming of the washer and smelled like rubber not electrical smell like a belt. could the problem be the belt and if so with belt and how do I get to the belts. Thanks for all your help in this matter. Tim
fairbank56
#2 Posted : Monday, September 23, 2013 2:32:21 PM(UTC)
fairbank56
Belts and pulleys are on bottom of machine. Tilt back for access. Rotate main pulley in center CW for spin, CCW for agitate. If it won't go CCW, check under agitator for clothing jamming it. If that's clear, take the dust cover off the main pulley and inspect the stop lug. The lug is splined to the transmission input shaft. The pulley has a "dog" on it that drives the stop lug which drives the input shaft for agitation. If pulley and stop lug are intact but you can't rotate pulley in CCW direction, the transmission is faulty.
Eric
wolf234
#3 Posted : Tuesday, September 24, 2013 8:47:49 AM(UTC)
wolf234
The pulley moves both cw and ccw. i moved the main pulley by hand and the belt. could the problem be the other belt because when the the washer is suppose to agitate it makes a high squeak and starts to smell like rubber burning. thanks Tim
wolf234
#4 Posted : Tuesday, September 24, 2013 8:57:06 AM(UTC)
wolf234
fairbank56
#5 Posted : Tuesday, September 24, 2013 10:09:20 AM(UTC)
fairbank56
Could be a faulty drain pump. Tilt the machine back just enough to see what's going on under there during agitation. Make sure the motor glides freely on the motor mount.
Whirlpool 6-2022030 Washer Drain Pump - AppliancePartsPros.com
Eric
wolf234
#6 Posted : Tuesday, September 24, 2013 10:44:21 AM(UTC)
wolf234
it does drain out it spins and drains out fine with no problem its when it suppose ti agitate that it makes a sound and smells like belt burning. thats why i was wondering about other belt
fairbank56
#7 Posted : Tuesday, September 24, 2013 1:21:16 PM(UTC)
fairbank56
Could still be the pump. Pump rotates in opposite direction during agitation. Need to determine if motor is running or locked up and just humming during agitation.
Eric
wolf234
#8 Posted : Tuesday, September 24, 2013 2:09:38 PM(UTC)
wolf234
Which pulley is the large one or the two small ones thanks sorry for all the questions Ijust want to know what to look for.
fairbank56
#9 Posted : Wednesday, September 25, 2013 5:29:24 AM(UTC)
fairbank56
Motor pulley is on the left, pump on the right, transmission in the middle.
wolf234
#10 Posted : Thursday, September 26, 2013 7:44:42 AM(UTC)
wolf234
The big pully does not turn when it it is suppose to agitate both small ones on the left turn. I propped the washer back as you said, now what? Thanks Tim
Guest (7)
2 Pages12>
