After coming to the conclusion that the mother board was the sourse of my problem, i got the replacement board, which as i have read would be a different model number, the wr55x10942. my original problem was that it would not defrost at all, when i changed the board out, i did not have any display control for setting temps. Help
Make sure all the plugs are plugged in properly in the new board.
Originally Posted by: av8or ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) After coming to the conclusion that the mother board was the sourse of my problem, i got the replacement board, which as i have read would be a different model number, the wr55x10942. my original problem was that it would not defrost at all, when i changed the board out, i did not have any display control for setting temps. Help I marked each of the plugs as i removed them from the old board, and double-checked as I put them back on the new board to make sure that they were in the proper location, and all pins were connected. The compressor and condensor motor did come on as soon as I plugged the unit back in. I noticed the row of jumper pins, and wondered if there was missing jumper blocks, as there were nun installed.
