Doug51
#1 Posted : Sunday, September 8, 2013 9:44:36 PM(UTC)
Doug51
I have a Maytag Neptune mah3000 aww that is no overfilling.
I have just had the bearings replaced and now have this problem here is what I have done in the way of troubleshooting
1. started to fill tub and pulled power cord out of the outlet, water stopped
2. took off back panel to access pressure switch, disconnected hose and blew into switch lightly water again turned off
3.blew into hose and heard bubbles coming from tub
Not sure where to look next
love the machine and really do not want to buy a new HE washer
Thanks for any and all help
Doug51
#2 Posted : Monday, September 9, 2013 1:44:42 AM(UTC)
Parts for Maytag MAH3000AWW Washer - AppliancePartsPros.com
Sounds like it is either the pressure switch or the pressure tube.
Check the tube for small cracks etc.
Since you probably disconnected the tube when doing your repair try cutting a half inch off of the switch end of the tube. Sometimes the tubing can stretch and not seal properly. Hopefully you have enough slack in the tubing.
If the tube checks out OK I would replace the pressure switch.
Washer overfilling (Washer Repair)
by 3DPiper 11/8/2016 10:23:12 AM(UTC)
GE Washer Overfilling (Washer Repair)
by Liriodendron 3/12/2015 11:48:35 AM(UTC)
GE Washer overfilling (Washer Repair)
by vman1 1/2/2013 10:39:21 AM(UTC)
washer overfilling (Washer Repair)
by runningspike 2/20/2011 3:03:46 PM(UTC)
Washer overfilling and not automatically spinning (Washer Repair)
by stubby0011 8/11/2010 7:50:33 AM(UTC)
help with GE washer overfilling (Washer Repair)
by doomee 12/15/2009 12:46:50 PM(UTC)
by scotte 10/7/2009 7:00:39 PM(UTC)
by jtowntbo5@yahoo.com 1/8/2009 7:24:04 AM(UTC)
dishwasher overfilling (Dishwasher Repair)
by Vulcan 12/14/2008 5:06:33 PM(UTC)
by xmasbaby63 8/16/2008 2:22:47 PM(UTC)
