TomHam
#1 Posted : Tuesday, September 3, 2013 1:00:20 PM(UTC)
TomHam
Quick Question:
The dryer symptom is "no heat". (was intermmitent, then nothing)
I checked the flame sensor with an ohmmeter and got the following:
- sensor window covered: less than 1 ohm (i.e. continuity)
- sensor window held in front of trouble light: less than 1 ohm (the same as above)
It sure sounds like the flame sensor is stuck closed, but is the trouble light a good enough test? Anything else I should look for?
Thanks for your time.
HumboldtRepairMan
#2 Posted : Tuesday, September 3, 2013 5:20:56 PM(UTC)
HumboldtRepairMan
Look all throughout the whole heating circuit.....thermal cutoff's, thermostats, thermal fuse etc etc
Gas Dryer Repair Video: Heating Problems - YouTube
Gas dryer flame sensor not tripping (Dryer Repair)
by Guest 6/1/2021 7:32:22 PM(UTC)
Dryer Flame Sensor (Dryer Repair)
by Dangilligan 9/9/2009 5:34:55 PM(UTC)
