reichegw
#1 Posted : Wednesday, August 14, 2013 10:10:34 AM(UTC)
reichegw
Keep getting a 'de' code which is door error which means door not closed and the cycle will not start. If we keep trying and open and close and giggle the door it will work and the cycle will finally start. We replaced the door latch/switch part and are getting the same error but now the door won't open at the end of the cycle. So we put the old switch back on and at least the door opens at the end of the cycle again. The wiring harness appears to be ok. This is very frustrating and I see many others on the web are having the same problem.
Does anybody have a fix for this problem.
HumboldtRepairMan
#2 Posted : Wednesday, August 14, 2013 4:34:25 PM(UTC)
HumboldtRepairMan
LG's are infamous for this because there parts are cheaply made....Same thing with Samsung same problems.........You may have gotten a faulty door lock try and return it if you can..........but more then likely it's the main board that's not sending the adequate voltage to the switch intermitantly..........Good luck.......
reichegw
#3 Posted : Thursday, August 15, 2013 3:51:23 AM(UTC)
reichegw
Thanks, I requested a replacement part.... At least I can try that again.
The main board is probably expensive and tricky to install.
#4 Posted : Thursday, August 15, 2013 5:14:32 AM(UTC)
The following manual may come in handy.
http://appliancejunk.com...ownloads;sa=view;down=17
You will have to join the site and then login to be able to download it.
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
LG Front Load Washer rotor only turns if given a push. (Washer Repair)
by Emailtim 6/5/2020 1:49:05 PM(UTC)
LG Front Load Washer Barely Spins (Washer Repair)
by mckennwa 3/2/2017 6:30:55 AM(UTC)
lg front load washer (Washer Repair)
by melindai 4/15/2014 4:32:46 AM(UTC)
LG front load washer repair- special LG tool to remove the door front seal spring rin (Washer Repair)
by Paul Lukitsch 2/8/2014 10:07:25 PM(UTC)
LG front load washer no power (Washer Repair)
by waxmanak 6/10/2013 11:35:46 AM(UTC)
Leaking LG front load washer (Washer Repair)
by klinkster 6/6/2011 8:27:07 AM(UTC)
Lg Front Load Washer (Washer Repair)
by GIACOMO21 5/19/2011 5:21:43 AM(UTC)
LG front load washer (Dishwasher Repair)
by skimanforu 7/22/2010 3:48:02 PM(UTC)
by Brandon1974 6/7/2009 3:54:12 PM(UTC)
