bobbijo
#1 Posted : Monday, August 12, 2013 8:17:27 AM(UTC)
bobbijo
About a year ago we started experiencing problems with our freezer. We originally thought that the kids weren't shutting the drawer properly. One time we came home and everything was defrosted. We threw everything out and it appeared to be working fine as long as the drawer was closed properly.
Several months went by and we would have this problem. Then it stopped making ice. Just when I would give up hope, it would produce ice.
Eventually, we stopped using it altogether. The refridgerator was working fine up to this point. We cleaned the cooling coils several times (but they are extremely difficult to access).
After we gave up on the freezer we started having issues with the fridge. It would be cold sometimes and our food began to spoil more quickly.
When I check, I can feel cool air blowing from the fan. I don't have a thermometer but I know it is above 40. I have cleaned the seal and made sure that this is not the problem. I did notice that the door does not "suck" closed like it used to. In fact, it used to be that if you closed the door and immediately tried to open it, you would not be able to because the suction was so strong.
Throughout this process, we have had excessive electric bills. I have been suspicious that the fridge is the culprit.
We had to have a MAJOR service call a few years ago and we had difficulty finding someone who was willing to work on it without removing it from our house, which is not feasible when you consider where we live. My husband has repaired most of our appliances in the past with the help of your repair forum. Hoping we can fix this ourselves.
Your specific questions:
Also have you checked the freezer and fresh food temperatures with a thermometer? No, I don't have one but I know they are too warm
Is the problem consistent or intermittent? started as intermittent and becoming consistent
Have you tried a colder freezer setting? Yes, doesnt seem to make a difference.
If yes, did it have any effect? It did at the beginning but slowly has gotten worse
If yes what were the readings? n/a
Is it always too warm? yes (it started as intermittent)
Are the compressor, condenser/compressor fan and evaporator/freezer fan running? I think so. I can feel air from the fan and I can hear the unit running
Also are they on all the time or do they cycle? I don't really know. I suspect that they are running all the time (hence the issue with the electric bill)
Have you checked/cleaned the condenser coils? Yes, several times. They are difficult to access and I feel that I haven't done a good job. I did notice a slight improvement when I did.
Bobbi Jo
#2 Posted : Tuesday, August 13, 2013 10:24:11 AM(UTC)
Parts for Whirlpool KBRC36MHS01 Refrigerator - AppliancePartsPros.com
You are going to have to check the evaporator coils at the back of the freezer.
I am assuming that the compressor is on all the time except when it is in defrost.
If the coils are heavily iced/frosted over then you have a defrost problem.
This could be the defrost timer, the defrost thermostat or the defrost heater.
If the coils only have frost in one area (usually where the freon enters the coils) then you have a sealed system problem. This will be an expensive repair as you need a pro.
Be sure that the compressor has run for at least an hour before checking for this. If you check shortly after or during a defrost cycle then you may end up with the wrong diagnosis.
This could be that the unit has a freon leak, a bad compressor or a plug in the sealed system.
bobbijo
#3 Posted : Thursday, August 15, 2013 7:47:45 AM(UTC)
bobbijo
We have taken a look at the refridgerator and it has opened up a whole new set of questions. We don't have a thermometer (we can't find it anyway) so we don't know the exact temperature of the unit:
1) Where are the coils located that would be frozen?. We looked at the coils on the top of the unit and there is no frost anywhere. The coils are room temperature or hot. The brass coils on top are hot and have melted the installation in some places.
2) The compressor is VERY hot, you would not be able to hold it in your hand.
3) We found a knob on the top of the unit (right behind where the cover comes off in the center) that was broken off. My husband was able to turn the knob (which we now know is the defrost timer). After it sat overnight, the fridge is somewhat cooler. We still don't have any significant cooling in the freezer.
4) The suction we used to have when we would open the door used to be so strong, that you could not open the fridge right after you closed it. That has been gone for some time. Today, when the fridge was a bit cooler, I noticed that some of the suction was back (not the way it used to be)
We found a schematic/manual of sorts inside the fridge.
Any additional information you could offer would be great. Let me know if I can provide any to you. We have everything pulled out of the wall so the sooner the better.
Thank you again.
Bobbi Jo
bobbijo
#4 Posted : Thursday, August 15, 2013 7:52:08 AM(UTC)
bobbijo
I forgot to mention that the compressor/fan appears to be running most all the time. Every time that I got to the fridge I have noticed that it is on and when I open it, I can feel it blowing air. The air is sometimes cooler than others, but clearly not cold enough.
bobbijo
#5 Posted : Thursday, August 15, 2013 7:53:57 AM(UTC)
bobbijo
Last thing, the evaporation pan had very old water in it. I appears that it has not been used or needed for some time.
#6 Posted : Friday, August 16, 2013 2:18:37 AM(UTC)
[COLOR="Blue"]1) Where are the coils located that would be frozen?.[/COLOR]
They should be in the freezer.
[COLOR="Blue"]2) The compressor is VERY hot, you would not be able to hold it in your hand.[/COLOR]
Probably because it is running all the time.
[COLOR="Blue"]We found a schematic/manual of sorts inside the fridge.[/COLOR]
I am unable to get the tech sheet so am having to just give general observations.
You have to get to the evaporator/freezer coils so you can inspect them.
When a compressor runs all the time and there is some cooling then there are two possible causes.
1. A defrost problem. The evaporator coils get heavily frosted/iced over to the point that the evaporator fan cannot pull air through them so it is not cooled properly. This is usually a fairly inexpensive fix.
2. A sealed system problem. Only part of the evaporator coils get cold/frosted. This could be a low freon or a compressor problem. This will be an expensive problem as you need to get a pro in.
Replacing a compressor is a fairly laborious task. With low freon the leak must be found and fixed before re-charging the unit with freon. Finding the leak also can be a pain and may not even be possible.
bobbijo
#7 Posted : Friday, August 16, 2013 7:45:07 AM(UTC)
bobbijo
After sitting for a full day, the fridge is cold again (I don't know the actual temperature, but it seems to be normal). The suction has also returned (this seems to be a very good sign).
The freezer is the same temperature as the refridgerator.
I will have my husband remove the back of the fridge/freezer to see what we can find. At this point, we have found coils on the top of the unit and nothing else. This unit has the compressor and coils on the top with the main unit in the middle and freezer drawer on the bottom.
Will let you know what we find today.
bobbijo
#8 Posted : Saturday, August 17, 2013 11:43:52 AM(UTC)
bobbijo
I just noticed that the model number is pulling up a whirlpool fridge. Not sure how that happened, but it is a Kitchen Aid Architect Series: kbrc36mhs01
Maybe this will help you find the exact schematic?
Thanks, Bobbi Jo
#9 Posted : Saturday, August 17, 2013 11:47:22 PM(UTC)
Kitchen Aid is made by Whirlpool.
File Attachment(s):
KBRC36M.pdf (183kb) downloaded 1 time(s).
bobbijo
#10 Posted : Sunday, August 18, 2013 11:27:52 AM(UTC)
bobbijo
Great, thank you. Turns out you have to take the freezer drawer out and get inside the freezer to see the coils above. Anyway, we found that the coils were frozen part way. We have called in a professional as you suggested.
The good news is, that after we adjusted the defrost timer, the refridgerator has gotten cold again and the freezer is colder than that. At least we will be able to keep our food cold until the repair man can get here.
I appreciate all of the help :)
Bobbi Jo
Guest (10)
