I was getting error codes F35 and SUD so I replaced the Pressure Switch W10415587. That was at noon today. For the rest of the day I have tried to get the machine to run a cycle but I keep getting error code F27. I hear the pump trying to pump out the water but it just pulsates and the water goes up and down in the white tube on right in the rear of the machine. The tub does not spin. On one try the tub did move to the right and to the left so I know that it can move both ways. I need help.
There should be tech notes under the top cover, so use them to test the motor control board and the door lock assembly. These Duets are extremely difficult to diagnose, and sometimes you just end up replacing parts until you find the combintion that fixes things.
But you should focus on the door lock assembly, the associate wiring and the motor control board.
Sid is right these duets are a pain and not a good investment.....The suds error here's some tips from the manufactures i've learned........USE ONLY "H/E" SOAP AND DO NOT USE DETERGENTS SUCH AS SUN, PUREX, KIRKLAND FROM COSTCO, ARM AND HAMMER------i've had sears and many manufactures have problems when these soaps on the newer units and i've seen crystalization and balancing issues with some soaps.... F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following:
1. First, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2. 2. Check the drain hose and make sure it is not plugged or kinked. 3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU). 4. Check/Clean Drain Pump Filter of foreign objects. 5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off 7. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pulling a vacuum on it with a shop vac. You may have an obstruction in the drain line or drain pump. It is also a good idea to check the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub and runs to the inlet side of the drain pump. This area can get clogged with small articles of clothing.
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the clear tubing (air hose) is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. This may generate an F27 error.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. Look for obstructions in the clean-out trap and impeller area of the pump.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off. You need to ask yourself if you find standing water in the tub when not in use.
5. The “Sud” error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent, HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause an over suds condition.
NOTE: Knowingly or unknowingly using the improper detergent on these model washers MAY void your manufacturer’s warranty. Read all instructions and documentation that comes with the appliance, thoroughly.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a component failure (more commonly, the CCU or pressure switch).
