Skully2014
#1 Posted : Wednesday, July 24, 2013 12:00:57 PM(UTC)
Skully2014
Looking for info on replacing or repairing the power coupling/ power line harness for my GE side by side refrigerator.
The fridge has lost all power to the temperature control panel. Ice maker still works, but dispenser has no power and does not work.
After looking at the power coupling and or power line harness at the bottom of the freezer door, it looks like one of the amps(?) is fried. Can this issue be repaired or replaced relatively easily? Thanks for any input.
richappy
#2 Posted : Thursday, July 25, 2013 1:44:29 AM(UTC)
richappy
You will need to splice the burnt wires below the door. You will need to pull off the fountain control panel and push down the wire harness. Either that, or remove the freezer inner plastic panel to do this.
