KERMITT454
#1 Posted : Friday, July 19, 2013 4:51:23 PM(UTC)
KERMITT454
I had some flooring work done and when they pulled out the stove they tripped the breaker, next day I reset the breaker. power comes on for the clock and element displays but the oven wont get hot/warm and neither does the elements on the top of the glass top.???
#2 Posted : Tuesday, July 23, 2013 1:42:50 AM(UTC)
A model number may help others help you.
Sounds like you have an electrical problem.
I am assuming this is an electrical stove.
The lights and control board run off of half the line (120 volts) but the elements require the full 240. On most units the oven and stove top elements are connected independently so when they all go out it is usually a power problem.
Try shutting the breaker off and then back on.
If this dowes nothing you will have to check the power at the wall receptacle for 240 volts.
If that is OK then check the power at the terminal strip in the unit.
