Modomo
#1 Posted : Friday, July 5, 2013 1:53:20 PM(UTC)
Modomo
Hi,
First off I entered the wrong model #. Should be FTFB4000FS1.
I have a Maytag front loader that is about 6.5 years old. Today I came home from work and found water on the floor of the laundry room. When I opened the washer door there was water in the tub up to the bottom of the door opening. I ran a drain/spin cycle. A few hours later I can hear water sloshing around in the tub when I move it back and forth. I suspect in several more hours I'll be able to see it filling the tub.
Any thoughts on what would cause this? Thanks
#2 Posted : Saturday, July 6, 2013 4:16:38 AM(UTC)
I cannot find any info on the given model number, please check it.
Sounds like the fill valve is leaking, I would replace it.
