RichL
#1 Posted : Tuesday, February 5, 2008 3:13:20 AM(UTC)
RichL
Brake makes a grinding noise when the spin cycle finishes and it engages to stop the drum.
What parts will be needed to repair this problem.
I ordered all parts that seemed to be brake related, but 2 parts where back ordered.
I want to make sure I do this right.
Any help would be greatly appreciated.
Thank you,
Rich
RichL
#2 Posted : Tuesday, February 5, 2008 7:34:23 PM(UTC)
RichL
Not Brake making noise, Tub "Spinner Top Assy." making the noise.
It keeps spinning on top of the drum when the drum stops, making a really bad grinding sound resonating through the drum making it louder.
I'm guessing it should not spin freely on top of the tub.
If I am right, should I replace this part (Maytag # 22004241)
Any insight would be helpful.
RichL
richappy
#3 Posted : Wednesday, February 6, 2008 2:14:53 PM(UTC)
richappy
Pull the tub top off, remove agitator(there may be a 1/4 inch screw near the bottom), then lift out spin basket, you will probably find a busted hub. Go to web site www.applianceaid.com for replacement info.
