OldJarhead
#1 Posted : Tuesday, July 2, 2013 3:23:31 PM(UTC)
OldJarhead
Washer runs fine in all cycles except rinse cycle, then just hums.
When timer knob is manually turned to spin, it completes the wash cycle.
I suspect a bad timer, but before laying out $$$ want to make sure.
Thanks!
fairbank56
#2 Posted : Tuesday, July 2, 2013 4:08:37 PM(UTC)
fairbank56
Where in the cycle does it stop? Where is the hum? timer, drive motor, fill valves?
Wash- fill, agitate, drain, spin
Rinse- fill, agitate, drain, spin
Eric
washer stops at rinse cycle (Washer Repair)
by scentsy 8/3/2013 10:01:48 AM(UTC)
Problem- Washer stops at rinse cycle (Washer Repair)
by zamana 1/25/2009 3:01:57 PM(UTC)
Washer stops at rinse cycles (Washer Repair)
by Aubriella 12/6/2008 5:58:24 AM(UTC)
Washer stops at Rinse Cycle and doesn't drain water (Washer Repair)
by kukoch 6/2/2008 9:22:18 AM(UTC)
