macman402
#1 Posted : Tuesday, July 2, 2013 9:19:07 AM(UTC)
macman402
The agitator is locked up and will not spin, it is making a grinding noise. I've replaced the clutch assembly approximately 1 month ago along with short cam agitator kit...
fairbank56
#2 Posted : Tuesday, July 2, 2013 10:59:25 AM(UTC)
fairbank56
Lower agitator or upper?
macman402
#3 Posted : Tuesday, July 2, 2013 1:06:24 PM(UTC)
macman402
It is the bottom agitator....
fairbank56
#4 Posted : Tuesday, July 2, 2013 1:11:12 PM(UTC)
fairbank56
Are you saying it won't agitate back and forth in agitate mode or it won't spin with the basket in spin mode?
Eric
macman402
#5 Posted : Tuesday, July 2, 2013 1:14:22 PM(UTC)
macman402
The basket will not spin at all....
macman402
#6 Posted : Tuesday, July 2, 2013 1:22:51 PM(UTC)
macman402
Water emptying but tub not spinning making grinding noise. Unable to manual turn tub
fairbank56
#7 Posted : Tuesday, July 2, 2013 1:37:42 PM(UTC)
fairbank56
Remove the cabinet, jump out the lid switch and run it in spin mode while observing the clutch hub. If the motor is spinning but the clutch hub is not, check the motor coupler. If it is good and is rotating the gearcase input shaft, the gearcase is bad. If the clutch hub is spinning either the clutch is faulty, brake cam driver faulty, brakes stuck, tub drive block faulty.
Motor must pause for a few seconds after drain in order to go into spin.
Eric
UserPostedImage
macman402
#8 Posted : Tuesday, July 2, 2013 1:40:39 PM(UTC)
macman402
Thanks, I will try that
