I just replaced the control module on a Bosh Axxis Washer (WAS20160UC). I powered the unit and initiated the variant coding sequence. I closed the door and rotated the dial to the 9 o'clock position. 9 solid lights came on, 4 went out. 5 LEDs in a column directly above the spin selection button remain solidly lit. All connections are firm. I cannot get to the start/pause flashing LED so that I can program the board. Any advice would be greatly appreciated.
Hi - I am having the exact same issue. Did you ever find a solution?
