twsno
#1 Posted : 12 years ago
twsno
Dried my usual load of clothes. Went to push the button to start the next drying for another load and nothing happens. It appears to be dead. Plugged and unplugged, cleaned the vent. Still dead. Any ideas?:mad:
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hello.
Please check first the circuit breakers. Look for a double breaker. Flip it off and then on.
If that trick doesn't help, you need to check the thermal fuse.
Unplug the dryer, remove the rear panel. The thermal fuse is located on the blower housing, next to the operating thermostat.
Part number: 3392519
Use a pair of pliers to remove one wire off the fuse. Check the continuity between the two fuse contacts. you should have <1ohm. If there is no continuity the fuse is burnt out and should be replaced.
The burned out thermal fuse is a sign of the restricted air flow. Clean the vents, inside and outside the dryer.
Also, the manufacture recommends to replace the operating thermostat along with the fuse.
Part number: 3387134
Use the video clips for the instructions.
Here are the breakdown diagrams and Bulkhead Parts, Optional Parts (not Included) parts for Roper RED4440SQ0 - AppliancePartsPros.com
Post the results.
Simon.
