Mr. mom
#1 Posted : Thursday, May 23, 2013 5:12:48 PM(UTC)
Mr. mom
I used the proper heating element, followed the instructions to a T and the dryer still doesnt heat....what else can it be?
Please help, kids have no clothes for school tomorrow :(
#2 Posted : Friday, May 24, 2013 12:33:02 AM(UTC)
Here are your parts, includes a wiring diagram.
Parts for Maytag PYET344AZW Dryer - AppliancePartsPros.com
Part of the diagram is missing. On the right hand side the RED wire attached to the MOTOR CENT SWITCH goes to the terminal strip in the unit re: L2.
Why did you replace the heater?
Was it visually bad or did you measure it and find it open or did you just feel it was the most likely cause?
You will need a meter to trouble shoot this properly.
First check the power. The motor, timer etc., all run off of half the line (120 volts) ( L1 to Neutral) but the heater requires the full 240 volts (L1 to L2).
You are messing with 240 volts so this is not a place to start learning about meter usage. Once you confirm that you have 240 volts then you can unplug the unit and use resistance (ohms) on the meter which is much safer.
You can then check the varios parts in the heater circuit.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
