gvel
#1 Posted : Sunday, May 19, 2013 3:38:09 PM(UTC)
gvel
The dryer heats for a while, and then the heat shuts off. It still tumbles. After a few moments, by shutting the dryer down, it will heat again.
Of course, the thermal fuse is ok, since the burner kicks in sometimes. It shows good continuity too.
Thanks, in advance, for your help.
#2 Posted : Monday, May 20, 2013 2:21:00 PM(UTC)
Hello,
Most likely the problem is a bad gas valve coils.
- The gas valve coil kit Part number: 279834
Part number: 279834
Maytag MEDC200XW1 - Intermittent heat and no buzzer (Dryer Repair)
by Lemarac 1/9/2019 4:09:17 PM(UTC)
electric dryer intermittent heat (Dryer Repair)
by wags1970 7/11/2017 9:31:33 AM(UTC)
gas dryer with intermittent heat (Dryer Repair)
by highpoint 1/21/2017 12:14:48 PM(UTC)
Intermittent Heating (Dryer Repair)
by lccent 8/7/2015 9:19:56 AM(UTC)
Intermittent heating. Now none. (Microwave Repair)
by bstruss 2/23/2015 6:29:10 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
by colbey 7/11/2014 4:55:38 PM(UTC)
LG electric dryer Intermittent Heat (Dryer Repair)
by Saurin 10/2/2013 7:41:23 PM(UTC)
by greg.od11@gmail.com 8/21/2013 3:29:48 PM(UTC)
Gas Dryer Intermittent Heat (Dryer Repair)
by FranDaMan 7/4/2013 6:53:18 PM(UTC)
Gas Dryer - Intermittent heat, checked coils and igniter (Dryer Repair)
by nevets 11/18/2012 6:14:02 PM(UTC)
by rcady52 10/26/2012 12:03:54 PM(UTC)
Whirlpool Super Capacity 465 Oven...intermittent heating issue (Oven Repair (including Ranges and Cooktops))
by wetzelbp 9/3/2012 4:25:33 PM(UTC)
Maytag Dryer Intermittent Heat (Dryer Repair)
by jayjaysin 6/24/2012 4:59:26 PM(UTC)
Whirlpool LGQ9857LW0 Intermittent heat (Dryer Repair)
by deanm11 6/17/2012 4:08:12 PM(UTC)
