The model number is actually TFX22ZR.
Well my refrigerator isn't working correctly and the coils in the freezer have enough ice to block the airflow. I turned the defrost timer to the defrost mode and the heaters don't work. I have not tested the heaters for continuity as the ends are heat shrinked on to the heaters but I would find it odd that both went out a the same time. I took the timer out of the fridge and tested for continuity. When turned the continuity on two of the terminals change so i assume that part it working correctly but I am not positive that the motor part is working correctly. That may be a mute point as when i manually turned it the defrost timers didn't come one.
How do I go about tracking down the problem?
Thanks for your help.
Groups: APP Team
Hello.
Please provide the complete model number of the unit.
Thank you.
Simon.
TFX22ZR is what was on the door. It does have the ice maker as well.
Groups: APP Team
Hello.
Look for the complete model number behind the toe grill on the right or inside the refrigerator section.Still missing 3 letters. You can check the defrost heaters and defrost thermostat at the 3 wire disconnect plug. Just trace the wires and check the continuity. Remember that defrost thermostat should be ice cold when tested.
Post the results.
Simon.
Originally Posted by: talbers ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The model number is actually TFX22ZR.
Thanks for your help. Talbers, To access the defrost heater Part number: AP2635761
and thermostat Part number: AP2639498
you'll need to empty the freezer compartment, and remove the rear wall, then you'll have access to the evaporator coils and components. Everything is probably frosted or iced over but you'll need to find the defrost thermostat. it should be "clipped to the back wall just above the evaporator coil, and disconnect the pink and orange wires, the thermostat should have a "closed" circuit on your meter if it's packed in ice or frost(you can remove it and place it in a glass of ice water if needed). When you find the blue wire to the heater, disconnect the blue and check across the blue wire to the heater and the pink wire to the thermostat, your meter should have a resistance reading of 20 to 22 ohms, any other reading indicates a faulty heater, and it will have to be replaced. If either of the heaters is shorted or broken, the heater will have to be replaced (they operate in a series circuit) if one is bad they both are bad. Your defrost timer Part number: AP2061708
Can be tested with a meter as well, terminal 1 to 3 is the timer motor, and should have a "closed" circuit at all times.You should be able to "feel" the motor running if you hold it in your hand just be careful not to shock your self. terminal 2 to 3 is the defrost cycle, it's the shorter of the two "clicks" and should be a "closed" circuit. Terminals 3 and 4 is the compressor circuit, it's the longer of the two clicks and should be a "closed" circuit. When the defrost cycle is active the compressor circuit is "open" when the compressor circuit is active, the defrost circuit is "open". We've attached a wiring diagram to assist you in testing and diagnosing the refrigerator circuits.
Thanks for the info. I will hopefully get time to check this out tonight and post my results back here.
Originally Posted by: talbers ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for the info. I will hopefully get time to check this out tonight and post my results back here. Thanks for the reply. I forgot to mention, there are several versions of this refrigerator. the parts and wiring diagram are for the "basic" early version. You'll need to use the complete model number of your refrigerator when ordering parts you need, but the basic information should still apply to the testing.
