jhf1
#1 Posted : 12 years ago
jhf1
My side by side defrost cycle will only start if I advance the timer manually. I have already replaced the timer and the bimetal def. Defrost works fine once it starts. When I replaced the timer it started to defrost right away, but will not cycle on its own.
#2 Posted : 12 years ago
Hi,
What is the part number of the defrost timer you installed?
How did you connect the new defrost timer?
jhf1
#3 Posted : 12 years ago
jhf1
i installed part 482493 and connected timer motor lead to terminal 2. Should I move it to terminal 1?
#4 Posted : 12 years ago
You hooked up the new timer wrong. That's why it did not work.
The new timer comes with the installation instructions (attached to the post). Per the original timer connections you have a continuous run timer application what means it has to be hooked up as instructed in Procedure 1. The timer motor lead should be connected to terminal 1.
File Attachment(s):
jhf1
#5 Posted : 12 years ago
jhf1
I switched the lead to terminal 1. I can hear the timer running all of the time now. Sounds like the issue is solved. Thanks for the tip Gene! much appreciated.
#6 Posted : 12 years ago
You are welcome. I'm glad it's up and running.
jhf1
#7 Posted : 12 years ago
jhf1
If you put your ear to the reassembled control panel and listen carefully you can hear the timer running.
#8 Posted : 12 years ago
That is correct.
Whirlpool WRF989SDAW02 36 inch Side by Side Not defrosting (Refrigerator & Freezer Repair)
by viking59 6 years ago
kenmore side by side not defrosting (Refrigerator & Freezer Repair)
by john 10512 11 years ago
GE side by side Not defrosting (Refrigerator & Freezer Repair)
by TOPGLOCK 13 years ago
jennair side by side not defrosting (Refrigerator & Freezer Repair)
by Tammi Card 14 years ago
maytag side by side not defrosting (Refrigerator & Freezer Repair)
by adamerik 15 years ago
Side by Side not defrosting (Refrigerator & Freezer Repair)
by pettinej 16 years ago
Amana side by side not defrosting (Refrigerator & Freezer Repair)
by eriksena 17 years ago
