drhunter
#1 Posted : Sunday, February 3, 2008 1:34:25 PM(UTC)
drhunter
ice maker not getting water. i have replace water solenoid,water switch,checked other switches and thermostat. looking like fridge may become new rifle target. any ideas as everything else works fine?
thanks in advance,
eddie
#2 Posted : Monday, February 4, 2008 11:12:43 AM(UTC)
Hi Eddie,
Did you check the water feeding tube coming into the ice maker? It could be frozen up.
You can use a hair dryer to defrost it.
If there is an inline water filter on the back of the fridge - how old is it? If it is more then a year old, it could be clogged, causing a restriction.
If this is not the issue then the ice maker itself is bad.
- The part number for the ice maker is AP3853272
