Wash cycle stops randomly, usually at rinse and spin cycles. Advancing the control knob slightly and re-starting, it will run till it reaches the next rinse cycle. Is this a timer or control knob issue.
Most likely the problem is restricted water flow due to a clog in the water inlet valve.
To supply you with the right part number for the water inlet valve I need the serial number of the washer.
