Jawin
#1 Posted : Tuesday, March 26, 2013 5:09:34 AM(UTC)
Jawin
It started with not spinning the water from the clothes. It pumps the water out when spinning and does spin fast enough to remove the water.
I used a different cycle than usual and it did spin out the water. When we try to do an actual wash in this cycle it wants to fill and wash at the same time.
fairbank56
#2 Posted : Tuesday, March 26, 2013 6:04:52 AM(UTC)
fairbank56
Faulty load sense switch. A very high failure item on this washer.
Eric
Jawin
#3 Posted : Tuesday, March 26, 2013 6:53:23 AM(UTC)
Jawin
Your link is to a Temperature Switch is this the same as the Load Sense Switch?
Thanks for the reply.
fairbank56
#4 Posted : Tuesday, March 26, 2013 7:21:39 AM(UTC)
fairbank56
Yes, it's a combination temp and water level controller.
Eric
Jawin
#5 Posted : Tuesday, March 26, 2013 7:28:24 AM(UTC)
Jawin
Appreciate it. I was afraid when we bought this thing the load sensing feature would be a problem.
Thanks again.
Guest (5)
