bjorkmd
#1 Posted : 12 years ago
bjorkmd
GE GSH22JTFA side by side is not cooling in freezer/fridge. Fridge sat for several months before a power on and when set to #5 setting for both it just blows out room temp air even after a day running. Everything looks clean in back and all fans are blowing as well. What might be happening?
Thanks!
richappy
#2 Posted : 12 years ago
richappy
If the compressor is vibrating and hot, your most probable problem is it leaked refrigerant. Get it re-charged and checked for leaks.
bjorkmd
#3 Posted : 12 years ago
bjorkmd
Thanks Richappy for response! The compressor felt warm and very little vibration after running for 2 days. Still just room temp air pushing through the freezer/fridge compartments. The fridge turns on/off just fine. Is there something possibly with the control board or starter relay? Good way to test that?
richappy
#4 Posted : 12 years ago
richappy
Seems like the compressor start device failed. Pry it off, if it rattles replace it.
