Court
#1 Posted : Saturday, March 16, 2013 12:41:47 PM(UTC)
Court
Dryer stopped working. Ran a load one night checked it in the morning and the drum was still spinning and the timer nob never moved.(thankfully it wasnt blowing hot air that whole time) very next day the dryer wont start. Tried multiple positions on the timer nob and checked the fuses. When i hit start there is a light hum but then nothing happens. My first thought is i need a new timer. Any insight on this issue?
#2 Posted : Sunday, March 17, 2013 2:21:11 AM(UTC)
Parts for Maytag AED4475TQ1 Dryer - AppliancePartsPros.com
You have to determine what the hum is.
If it is coming from the motor.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit. In this case you will probably have heat when the motor is not turning.
File Attachment(s):
AED4475.pdf (182kb) downloaded 1 time(s).
