Jwatts807
#1 Posted : Sunday, March 3, 2013 5:29:13 AM(UTC)
Jwatts807
I have a Roper washer. The cold is not working. It does hum. Warm and Hot both do work. Thank you.
sidfink43
#2 Posted : Monday, March 4, 2013 9:31:47 AM(UTC)
sidfink43
Your warm is probably not working either, since it is a mixture of hot and cold and you are probably just getting the hot.
You should use a meter to see if you are getting voltage to the cold solenoid. An easy way to do this is to take off the cabinet and switch the connectors on the hot and cold water valve. If in this case you get cold but do not get hot, then the valve assembly is okay and the problem can be in the timer or the water temp selector.
If you don't get cold when you call for hot then the problem is likely with the valve assembly.
Roper washing machine agitates but won't spin out. (Washer Repair)
by Ktlyn129 7/20/2014 4:13:09 PM(UTC)
Roper Washing Machine (Washer Repair)
by rthiede03 8/21/2013 11:59:11 AM(UTC)
roper washing machine (Washer Repair)
by RICHARDH43X 8/31/2012 11:01:04 AM(UTC)
by hampton warrior 5/8/2011 10:57:07 AM(UTC)
Roper washing machine-broken fin on agitator (Washer Repair)
by mundopio 9/7/2010 12:32:27 PM(UTC)
Roper Washing machine agitates but shuts down close to the spin cycle (Washer Repair)
by clancast 9/27/2009 10:54:29 AM(UTC)
by Phillip D Webb 5/26/2009 8:32:33 AM(UTC)
by brandysimon 5/19/2009 4:05:14 PM(UTC)
Roper washing machine clutch testing (Washer Repair)
Belarus cpokol 12/30/2008 1:58:41 PM(UTC)
Roper washing Machine (Washer Repair)
by garyspi 8/14/2008 7:29:26 AM(UTC)
Roper washing machine shaking violently (Washer Repair)
by texasgal 6/2/2008 7:19:26 AM(UTC)
by Tree 4/21/2008 3:56:01 AM(UTC)
by lorijoecanterbury 4/14/2008 2:01:50 PM(UTC)
Roper washing machine stuck in spin cycle (Dishwasher Repair)
by jskogsberg 2/7/2008 10:44:22 AM(UTC)
Roper washing machine shakes during spin cycle... (Washer Repair)
by zoe1594 1/6/2008 4:12:36 PM(UTC)
