Have a Samsung RS263BBSH side by side. With no prior misbehavior on one use this afternoon the water dispenser in the door would not shut off.
The lever in the door at least feels normal. It travels back and forth as it always has. Is the problem more likely a water valve or some part of the mechanism in the door?
Just hoping to get an experience insight before ordering parts in the dark. Thanks.
Apparently no one had an idea to share. Would've bought whatever part was the most likely suggestion from whomever took a moment to post and help. Just ordered a water valve from some generic vendor on ********. It may be wrong but it was at least really cheap....
