Hot water does not dispense into the washer on any of the water temp settings. If I switch the water lines, hot water will fill up via the cold water setting. I already checked the hoses, water supply, and power. Note: I replaced the Water Inlet Valve yesterday with a brand new unit and the problem remains. All other functions on the washer are okay. Any suggestions are appreciated. Thank you. Chris
Bad water temp selector switch. Could also be a bad connection/wire between water temp switch and timer/water inlet valves. Inspect those first and check with meter if you have one. Eric
I appreciate the suggestion - I should have first checked the connection/wire between water temp switch and timer/water inlet valves.
It just may be the switch. I went for the cheaper part replacement first.
Thanks again.
