I removed the drum and got to the burner assy, when I turn the dryer on the igniter does not even warm up. I don't have an ohm meter. I assume the igniter should be glowing?
Originally Posted by: SCOTT4 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I removed the drum and got to the burner assy, when I turn the dryer on the igniter does not even warm up. I don't have an ohm meter. I assume the igniter should be glowing? I figured it out, I made a jumper wire and jumped the thermal fuse and was able to determine the fuse was bad...popped a new fuse in and I'm back in buisness.
