jesus villanueva
#1 Posted : Tuesday, January 29, 2013 6:21:27 PM(UTC)
jesus villanueva
the water level does not work properly
set at high level and it shuts off with less then min amount of water
must reset to high every time till right amount of water is in washer.
#2 Posted : Wednesday, January 30, 2013 1:44:05 PM(UTC)
Hello,
Make sure there is no water in the washer. Open the control panel and disconnect the pressure hose (clear plastic tube) from the water level switch. Blow some air through the hose to make sure it is clear. Reconnect the hose and give it a try.
If it would not help, replace the water level switch.
- The water level switch Part number: W10339334
Here are the breakdown diagrams and Parts for Maytag MVWC300VW1 Washer - AppliancePartsPros.com
LG top loading water level not correct (Washer Repair)
by Guest 12/7/2023 6:44:59 AM(UTC)
GE Washing machine water level problem (Washer Repair)
by Guest 12/3/2022 12:53:02 AM(UTC)
LG WATER LEVEL SENSOR (Washer Repair)
by NicholaF 9/20/2022 9:59:26 AM(UTC)
Auto Sensing Water Level (Washer Repair)
by nwr251 7/21/2022 4:23:08 PM(UTC)
Low water level in GE PDW8280 (Dishwasher Repair)
by b707guy 8/1/2021 1:49:44 PM(UTC)
New Maytag Washer Water Level (Washer Repair)
by RCRICK 1/8/2021 8:36:02 AM(UTC)
Need To Increase the Water Level (Washer Repair)
by retab12332 12/2/2020 1:54:37 PM(UTC)
Setting water level on old(er) Whirlpool top load (Washer Repair)
by M Yaworski 4/12/2020 11:54:35 AM(UTC)
GE Dishwasher water level about 1/4" too high (Dishwasher Repair)
by sup 1/4/2018 5:49:22 PM(UTC)
water level control (Dishwasher Repair)
by pfoxharp 12/29/2017 7:15:54 AM(UTC)
Whirlpool rinse water level low (Washer Repair)
by g20zoom 8/19/2016 6:49:58 PM(UTC)
water level pressure switch (Washer Repair)
by onesunshine 11/29/2015 5:23:33 PM(UTC)
Water level too low (Washer Repair)
by asagy 10/22/2015 5:16:26 AM(UTC)
How replace water level knob on Kenmore (Washer Repair)
by John7778 8/20/2015 9:53:43 AM(UTC)
Roper Whirlpool Washer - Water Level Knob Won't Turn (Washer Repair)
by jonnyv88 8/12/2015 5:54:48 PM(UTC)
